I don't think so.......
http://www.amazon.com/gp/product/B0...&tag=pressurewashr-20&linkId=MEL7IZSPASBG36G5
http://www.chacha.com/question/what-is-the-most-expensive-washer-and-dryer
http://www.ebay.com/itm/NASA-SPACE-SHUTTLE-CHALLENGER-FLOWN-IN-SPACE-WASHER-/221255497490?rmvSB=true
...but seriously......I am collecting ideas and parts to attempt a build of an EDM machine. There certainly are many different designs once you start searching around.
I have divided the ones I've found into 3 different groups:
1) vibrator with discharge circuit in series with the electrode control; manual advance
2) vibrator with separate discharge and control circuits; manual advance
3) stepper motor (much more complex control); automatic advance
...and that does not even consider different discharge voltage amplitudes, polarity, constant vs. pulse voltage, dielectric fluids, pumps, etc.
I suspect that:
For 1) the power supply, coil, total head mass and discharge capacitor need to be tightly tuned to work well together.
For 2) since the discharge circuit is separate from the head control circuit, the parts could be chosen more independently.
For 3) it is a significantly more complex build, however, using a stepper motor driver from a third-party supplier, it may be much simpler than previously published builds. Also, as long as the total head mass is within the capacity of the stepper motor/lead screw it should be more independent of chosen parts.
I am not sure which type to try first. If I had the time I'd build them all and test each. However I suspect 2) to be the best "bang for the buck" in terms of part tweaking and time/money invested.
I have a few other projects on the go too, but hope to try some of this over the next 2 weeks.
-brino
