About a week ago I was working on the JET Mill's Z-Axis Powerfeed. At that time I had completed the installation of the Limit Switch Bracket.
The two tasks that remained were the drilling of a 5mm hole into the shaft of the Powerfeed followed by inserting a spring pin into the hole.
I procured a set of metric drill bits earlier this week. Today I thought I had time to finish this project.
The 5mm hole needs to be drilled where the white arrow is pointing.
I was concerned about my ability to drill a hole freehand through the coupler. I thought it would be better to do this on the JET Mill and then use a hand drill to finish the job on the shaft. I was playing around with how to set this up when I heard a small voice whispering in my ear...
"Is it possible", the voice said, "that drilling through the coupler without it being on a shaft will gall the internal threads?"
This did seem like a reasonable concern and I could fix it (I thought) by inserting a bolt into the coupler during the drilling process.
Without thinking about it too much, I grabbed the coupler and went back to the house basement where my hardware cabinets are. I had some 3/4" bolts and some 1" bolts. The coupler fell somewhere in between. The largest metric bolt I had was 14mm - much to small.
Off to the local Hardware Store. The Hardware Store had 7/8"-9 bolts and that barely started to thread onto the coupler and then stopped. The largest metric bolt they had was 16mm. I was leaning towards this being a metric thread at this point and I was guessing at a size of 22mm.
A Tractor Supply store was close by and they tend to carry larger hardware but I didn't know if they were going to have metric in larger sizes. They had 20mm but no 22mm bolts.
I returned home and did what I should have done before I went on that wild goose chase. I measured the shaft's threads.
I got a surprise.
The metric thread gauges didn't really match. 2.0 pitch was close but didn't quite match.
SAE 12 matched exactly! I measured across the shaft's threads with a calipers and came up with .853"
7/8"-12?
22mm with not quite 2.0?
Two questions:
What thread am I dealing with here?
Do I need to be concerned about damaging the threads if I drill through the coupler without something threaded through the coupler?
Scott
