- Apr 23, 2018
- 6,880
This is my Jet 2" belt sander/grinder. There are many like it, but this one is mine. My dad passed it down to me while he was in the tool and equipment business in the 1980s. He kept the 3/4 horse version, and I got the 1/2 hp (which means it has enough power half the time). Anyway, this guy has been a real workhorse for me.
I was running it the other day, and it was dropping RPMs until startup engaged, then it would run up to speed and start dropping RPM again. The start circuit would engage and disengage with every run up, tick-tock, tick-tock. It wasn't doing that last time I used it. I put my hand on the motor, and blew up with bad English when I found it to be around 200 degrees Fahrenheit.
The first thing I suspected were the bearings, but when I fired it up again later the problem had vanished. There wasn't any kind of sound coming from or drag fighting the motor shaft, so maybe it's not bearings. It didn't get hot again, and ran normally, so maybe it's gone... but I know no mechanical problem stays gone for long.
Can anyone give me some tips for how to troubleshoot an intermittent like this? It's easier to troubleshoot a fault as it is occurring. Next time it heats up, I'll find out where the hot spots are with an infrared thermometer, but if it doesn't come back, what are some likely culprits? This has been a good machine for a long time, I'd like to keep it that way.
Thanks!
Thanks!
