- Jan 26, 2021
- 345
Thanks! I'll try and gather some pics of the shop.Wow, that looks fantastic.
As an obvious thread hijack, based on the checkerplate walls and the tidy machine base I'd love to see the rest of your shop.
Rent a gantry crane?I did some measuring and I don't think an engine hoist is going to work to get my mill up on to the stand. Since the stand will be bolted to the concrete base it's basically permanent in it's location. I think the lower legs on an engine hoist will hit the wall behind the stand before the mill is in position over the stand to lower it. Not only that but I think the legs will interfere with the concrete base as well. I'd use my Bobcat front end loader but it won't fit through the door way into the room where the mill will be. I may have to break the mill down into three or four manageable pieces and reassemble on the stand. Any other ideas?
I did call the local rental store and they have an engine hoist with parallel legs 36" apart. That would for sure straddle the base just fine. I will drive over and look at it.I would go with Blades idea.... but my engine hoist does not have retractable legs and they are also narrow so may not fit around your stand. But maybe a rental unit will work.
Getting close. I need to add the power feeds and wire the plug and a few other odds and ends.Looks great! Needs some chips and oil on it now.
