The motor tag indicates larger than 1 hp.
Stick with 240 vac equipment and avoid voltage converting types as well as the Chinese branded units.
We prefer Allen bradley and other have theirs so brand does not really matter that much.
But regardless of brand download the manual before buying to verify first that it will work with single phase supply then look for a table that shows which unit to use for your application.
Some need to be De - rated for single phase while others may not work at all or bi in alarm.
After that read the installation and configuration instructions to be sure you can figure it out.
Ours has a 3 wire control option that has run and reverse as 2 wires and stop as third.
The Drum Switch Has 3 Sets Of Contacts So Slight Mod To Insure ONE Set ALWAYS makes first and used for stop and the operation is just like factory.
A pot is located elsewhere for speed control.
Made a frame that is mounted to the bolts for the chip tray and everything (vfd in box, for bar and pot main power switch) all are mounted to frame so the complete lathe is stock other than longer bolts to support frame and modified drum switch.
Can do MPR minutes per revolution without back gear via vfd.
