- Apr 14, 2014
- 3,546
If I were doing it I would place a test piece in the chuck. Measure the amount you want to take off with the DRO And score a line. Then turn the compound to 35* similar to when making a taper for a dead center and zero the cross slide. Slowly remove material until you reach the score line.
Set the carriage stop at this point and note how far you’ve moved the carriage in the Y direction. If the parts are all the same length and diameter the bevels should be identical.
