Interesting Metal Work I have Seen
I cut a bunch of random length hex. I held them together with a band clamp so the bases were aligned flat. I welded all the bases together. I took some pipe and turned it to 1" and squared the ends. Then I welded the group of hexagons to the end of the pipe. I made sure the cluster was larger than the pipe. I then ground the hex cluster round on the belt grinder and finished on the disc grinder. The whole thing is 304.
I'm thinking a longer one with both ends finished this way would make an awesome towel bar.
Robert
