- Nov 15, 2016
- 943
Basically you can never have enough tools or a big enough shed .
I have 1,2 & 4 oz ballpein hammers that I use a lot, favorite socket set is 1/4" & 3/8" Metrinch with extra extensions. One of those sets of 100 1/4" drive does everything sets with Torx, security etc tips. Top quality pin punches are a must as are a selection of pliers and I only trust genuine Channellock slip jaws.
Inside & outside calipers and 6" verynears and some good scales.
Everything listed above. As per usual mikey has pretty much nailed it.
One thing I use a lot is a 6" Brass wire brush on the polisher, not as aggressive as the steel wire on a grinder so can be used to clean rust off Chrome, clean threads etc and much general light cleaning, use the steel wire brush mainly for deburring. Especially good for sheetmetal edges.
