Clif, What printer do you have?
Several;
My first a Anet A6 is undergoing an almost complete rebuild, due to a mother board failure plus the normal upgrades most Chinese prusa i3 clones get. (Got it off Amazon)
The printer I used for this print was a Hictop Ender 2 (Got this one off ebay)
I would recommend this as a starter printer for most who are willing to do a relatively simple build. It took me less than an hour to put it together and get a print started, where as the Anet took over 8 hours. Be forwarned there is a learning curve here, just as with any new type of machine.
As far as material to use to print gears. PLA the easiest to print is the most brittle and weakest, however oil doesn't degrade it. ABS I would NOT recommend because of the problems with both warping and need to exhaust the fumes, PETG is better here, but Nylon is even better.
IF you want to learn a bit more four people with u-tube channels I could recommend are;
Thomas Sanladerer:
Makers Muse
3D Maker Noob
3D Printing Nerd
I know even more u-tube channels to waste time on, however most everything I know I learned from these people and a couple others.
One last thing, I am waiting for the Prusa MK3 from Prusa Research, because I want a better printer to work with, and Josef Prusa is the originator of the I3 design, the chinese are so fond of cloning. Should arrive at the end of the month.
