- Oct 19, 2020
- 159
I am getting to know my 1974 South Bend 10K. One issue I am working on is how to comfortably monitor the position of my cross slide during turning. Its a challenge for me to see the marks on my cross slide dial. So I would like to set up a dial indicator to make it easier to see. With the tools I have, I can do it but not efficiently as shown in this pic. I used a magnetic holder stuck to the apron with a dial indicator swung up around touching on my tool post.
It is a bulky and awkward setup but it is much easier for me to read than my cross feed dial.
One problem is that the area where my magnetic base is stuck is not flat so it doesn't seat firmly. If you look at this pic you will see that its mounting surface is rounded slightly.
Do any of you have a cleaner setup you can recommend or comments on using a dial indicator as opposed to squinting at the dials? Thanks.
