I agree that the feet thing looks wiggly - any vibrations are carried by 4 points, maybe four 1/2-13 bolts. The bolts in the tube through the base are not really doing much of anything structurally, more positionholder. Rule of thumb for plug welds: min diameter is 1.5 times material thickness for structural applications, let's you get some heat in the hole before you close it up.
The bolts through the base of the mill are 1/2-13.
The leveling feet assemblies have 5/8in diameter studs and are rated at 4500lbs capacity each. They will only be carrying 600lbs each statically. I think there is plenty of margin on the leveling feet.
