Why not use square bar instead of tube and drill and tap that?
I like your idea about a thicker piece of flat stock placed inside the tube, but instead of 'pinning' it, I would drill holes in the tube, locate the flat stock, and then 'plug weld' the stock to the tube... then locate the 1/2-13 holes and drill/tap with the flat stock in place.
FWIW, I have welded flange nuts in steel tube also...
-Bear
Hi Bear
I like this idea.
I could pre-drill and tap the 1/2-13 holes in the flat stock, bolt it in place inside the tube for registration, and plug weld the two together. Remove the temporary bolt, and voila!
If the plug welds were far enough away from the threads there would be no HAZ issues.
The plug welds would basically be a "heavy tack" correct? How big should the holes for the plug weld be, practically speaking?
