FIRST,KNOW THIS: A 9" SB lathe is a very light lathe,and the bed is quite flexible under the load of a cut. This lathe cannot operate well sitting on a flimsy floor. Especially the longer bed models @ 32" between centers. This is not to say that it is not a good lathe. But it needs to be set up properly. You also need to know how to EXPERTLY grind your cutting tools to avoid chattering,uneven cuts,and other problems. What you NEED to do,is cut a rectangular hole in your particle board floor. Dig a hole 2 FEET DEEP to fit the hole you sawed out of your floor. FILL the hole(in the ground) with concrete. Make the surface of the concrete as smooth and even as you can ! Sit your lathe cabinet on that concrete foundation and it will not move about when you are walking on that flimsy floor. Make sure all 4 feet are sitting snugly on the concrete. If not,shim the leg that needs it with a tapered OAK wedge.Then,you can properly level your lathe.
I doubt that you can swivel the headstock on a 9" S.B. lathe. The V way goes all the way under the head stock. To get the lathe so it makes a true cylinder the same diameter its full length you do not need an expensive level. You need to first make sure the tailstock is perfectly centered on the bed. Put a NEW,sharp pointed #2 MT center in both the headstock and the tailstock. Bring the tailstock right up to the headstock. Get the 2 centers nose to nose. Look straight down on them with a 10X loupe. Adjust the tailstock sideways till you can see that the 2 points are dead aligned. Look sideways at the centers too. Tailstocks can easily get worn,and become LOWER than the headstock,from being slid about. NEVER SLIDE THE TAILSTOCK over DRY ways. It will wear both the tailstock and the SOFT ways on a 9" S.B. lathe. If the tailstock center is below the headstock center,you must loosen the bolts on the sides of the tailstock and lift it so you can put shims under the top half of the tailstock. DO THIS EVENLY EVERYWHERE,or you will end up with a tailstock that may be as high as the headstock,but may be pointing downwards(which is the usual problem). To check for a down pointing tailstock,after you get the points equal in height,with the tailstock quill nearly fully retracted into the tailstock,EXTEND the quill out ,lock it,and see if the points of the #2 MY centers are STILL the same height. If they are not,you need to add shims like you did before EQUALLY on both sides of the tailstock. Do this until you can be sure that the tailstock quill is PARALLEL.You keep checking the height of the 2 MT centers from a sideways view. THEN go back to viewing from above the lathe,and make sure that the centers are perfectly nose to nose.
NOW you are ready to "level" your lathe. Put a bar of steel or aluminum in the lathe. Have it about 18" long. It is a good idea to take sone fairly deep cuts in the center area of the bar,leaving both ends the original,full diameter. Then,take a LIGHT cut off both ends of the bar. If the lathe is aligned,the ends should be the same diameter. If the tailstock end is SMALLER,put a few shims under the FRONT side of the lathe's rear foot..If your bar is too large on the tailstock end,put shims under the back side of the lathe's rear foot. Experiment with shims,repeatedly cutting the test bar,until it is the same diameter on BOTH ends.
It does help a light lathe like the 9" SB,to mount it on a 1/2" thick steel plate. Much thicker than that,and you'll need MUCH HELP even lifting the plate!! I have plates of 1/2" bronze 1' x 4'. Each one weighs 100#. And,you'll have a terrible time drilling 4 holes through a thicker plate unless you can get it onto a drill press. If you have to use a hand drill,make a smaller hole first,then drill your larger hole. It will be INFINITELY EASIER to first drill a small hole first. 1/8" diameter is fine. Removes the pressure of the center of the larger drill. The centers do not cut very well.
If you get both ends of the test bar to cut to the same diameter,try cutting the FULL LENGTH of another test bar. If your test bar is the same diameter at each end,but LARGER (shaped like a wooden barrel) in places,your lathe's bed is WORN,and needs to be re cut,re scraped or re ground. That costs big money. But you can live with it by filing long pieces till they are equal diameter all over. Short parts will likely be o.k.,unless your lathe is really badly worn.
This is the straight dope on how to get the maximum accuracy out of your light lathe.
