- Jan 20, 2018
- 5,890
Way back in 2016, when I got my $50 Lincoln AC225, I bought the cheapest most economical auto-darkening hood I could find on Amazon. I paid $20. It got little use until I got my TIG welder in 2018, when I started using it fairly regularly. Aside from not accepting a cheater lens with some modification, it's been perfect. Never failed to darken, never went dead, never had to replace the battery. Seeing all the large lens, natural color hoods available, and having a little money to burn, I started casually looking around. A couple of weeks ago, I found a deal I couldn't pass on Temu.
It's not the large window, but it is natural color. The LED lamp is a nice touch, has spot and flood, is extremely bright and rechargeable (even came with USB cable). It also does not accept cheater lenses, but I'll do the same thing I did with my old one. The headgear is light but I was able to adjust it properly and it seems to retain the adjustments. I used it to do a little stick welding outdoors today and it functions perfectly. For $40 I am quite impressed.
The grandbaby says I look like Ironman.
Welding Hood Auto Darkening Welding Helmets Men Solar - Temu
1pc welding hood auto darkening welding helmets for men solar 2 clarity welding mask 2 arc sensor wide shade 9 13 welder helmet with grinding cut for mig tig arc at the lowest price at Temu.
www.temu.com
