- Jun 7, 2013
- 10,450
When I took a machine shop class in high school, we were given a piece of key stock to grind into a roughing tool with ground in chip breaker; when we could show the teacher we were capable of grinding an acceptable tool, we were given a new tool bit to keep for the year's classes; that and a round nose tool were our cutting tools for the class. He also had U shaped adaptors so that the 1/4" square tool bits could be used in the Armstrong tool holders for the larger lathes that used 3/8 square tools.Not sure if they're making bits or not but you will find them for sale on ebay.
My best advice - buy some mild steel keystock in the size you plan to use and learn to grind tools with that. When you can grind a tool shape you are satisfied with then change to M2 HSS. When you have M2 tools that work as you intend, try cobalt or the Tungsten tools. Trust me; grinding cobalt as a first tool does not usually work out well. They take more skill to grind well.
Clearly, Chinese bits are the cheapest way to go. My experience is that they do not hold an edge as long but they work pretty well. When I experiment with a tool, this is what I use until I get it exactly right. Then I grind one from a blank I trust.
I had one of the best teachers ever, this back in 1962-3 at Napa High School Ca., Paul Goldberg, later changed to Kreuger. He apprenticed at Mare Island Navy Yard in the 1930s and was an apprentice school teacher after that until after WW2 when he taught in the public schools. Nothing went on in HIS shop that he was not aware of; he had a finely tuned ear to noises that meant trouble, and was on top of everything, and no screwing around in class!
