As someone said that's a tuff one to learn on....here is how I fix the buba drilled off center broken screws.....I set up the receiver in my mill index off the good screw hole move over the bad one and machine the screw and hole out with a center cutting carbide end mill, retap to a larger screw depending on how messed up it was, make a plug to go in the larger tapped hole screw it in with red lock tight , but not too deep....machine the plug down close and then file/contour to the receiver....then find the correct hole location and drill a new hole in the installed plug and tap to 6-48...cold blue and install the scope mount......I have fixed quite a few like this ................
