- Apr 27, 2021
- 30
I'm trying to turn the part shown in cross section below. This part is about 1.5" in diameter, steel. I know how to do the individual operations, but having trouble with the order of operations. At this point I have machined the entire part, except for the inset on the large diameter (shown by arrow). I don't have a good way to mount it in the chuck. If I mount it as shown, I can only grip maybe the leftmost millimeter of the part, which doesn't seem like enough. If chuck it the other way, I'm afraid the jaws will bend the 'bell', plus it will be a left-handed facing operation.
There's a trick in woodturning where you glue such a part to another piece for mounting, then separate at the glue line afterwards. I'm not sure that this is safe for a metal lathe operation.
Were I to start over (which I will, if I have to), I could leave enough extra material on the left hand side to mount, but then after separation, I'd still need to turn the 'cone' on the left hand side, which would mean gripping by the 'bell', so I'm not sure that helps. I guess I could mount by gripping the inset, with the 'lip' resting against the jaws - that seems best.
Any advice or suggestions?
