- Dec 20, 2012
- 9,422
See post #4 of this thread to see what your compound angles should be set to.
So I should rotate the compound adjustment dial to the right, or towards the tail stock until it is lined up with what would be on out import machine 60.5 degrees.That pic explains a few things! I can't believe you could cut any thread like that. Rotate your compound back to pass your zero mark and then keep going until you get to 60.5 deg. That should be the correct angle on your machine.
Your machine is labeled like mine such that 0 deg is parallel to the bed. That is non-standard.
By the way, we are NOT referring to the tool angle. We are referring to the axis of compound travel. Is that the point of confusion?
R
can anyone explain with pictures how to precisely measure angle of compound slide axis.
