- Feb 18, 2016
- 451
Just as an aside:
I thought I should mention this while I'm on the topic.
I originally wasn't planning on using the X-Y vice cross-feeds for actual cutting. I really only bought this X-Y vice for the height it offers.
But on this project my workpiece was 5 inches long and my lathe cross-feed only travels about 4.5" of useful travel. So it turned out that I had to use the crossfeed screw on the X-Y vice to finish the last 1/2 inch of cut. And that worked out real slick. So that was a nice feature. Saved me from having to reposition the workpiece in the vice and starting over. So this X-Y vice will actually extend my milling range by an extra 3 or 4 inches. That's kind of interesting. I didn't really buy it for that, but hey, it's nice to have.
Here's the vice I bought from Amazon. It was just under $60.
WEN 414CV 4.25" Compound Cross Slide Industrial Strength Benchtop & Drill Press Vise
It's certainly not the greatest. But for the price it ain't bad. Like I say, when I bought it I was just buying it for the height.
I wasn't even thinking of using the X-Y feature other than for just quick set up. Also, I keep these gibs pretty tight. I wasn't planning on using the X-Y after initial set-up. But as it turns out, it came in handy after all. If you're looking for high precision though you'd definitely be far better off buying a much more expensive X-Y vice. But hey, for 60 bucks this baby ain't bad. I'm happy with mine. Take good care of it and don't abuse it and it should last quite a while. Put big heavy stuff in it and beat it up and it will probably break fairly easily. So beware of that.
