I hate to point this out but your probably have the tool you need right in your toolbox. The operation you're describing could be done with a file in less time than it took me to read this thread. I'm not trying to be mean, just pointing out that it doesn't take $10k worth of tooling to do a 10 cent job.
You're absolutely right. If my goal was to just clean up the inside corner of this piece of angle iron I could have done that a long time ago in 5 minutes without any machines at all. That's not the point of this exercise. The point of this exercise is to increase the capability of this machine. This isn't the first time I've wished I could raise the vice, and I'm sure it won't be the last. In fact, before I bought this tall X-Y vice it was basically impossible to use the milling head at all as the lathe table is simply way too far beneath the milling cutter. The X-Y vice already give me about 5 inches of height. But even that is still not enough. I was thinking of a second solution, and that would be to simply by yet another small vice to put in the jaws of the X-Y vice. That would probably work too. I'm sure there's more than one way to skin this cat.
Not sure of the dimensions of your vise base but have you considered using a piece of 3" x ? box tubing as a riser? I've got a piece of 4" tubing that I have machined all 4 sides parallel that functions as both an angle plate and riser when needed.
That's a great idea. In fact, it sounds like a good idea to have several of those laying around for various jobs. I don't currently have any box tubing laying around. I'm just getting back into machining again. So my scrap metal pile is currently non existent. That's going to change over the course of this summer though.
Save up enough money for a Bridgeport before you start looking that way you can jump on it when you find one. Trying to save for a machine that is available right now never works out for me, someone always beats me to it...
You're right. I'm dreaming too soon. I also need to put a new clutch in my truck before I set out to pick up any heavy machines.
The a new clutch and pressure plate are on order. Only $53, I was shocked that I could get a new clutch and pressure plate that cheap. And I'll be installing that baby myself for free. That's the only way I can afford to save up money to buy machines.
I was actually looking at a mag chuck for $69 too, but that's gone as well.
The only two items on my wishlist that are still available are the following. But they'll probably be gone too before I get the clutch installed in my truck.
South Bend Lathe - $1,100
I'm sure that will be gone before I can get the truck repaired.
Also a Surface Grinder - $235
There's no mag chuck with it, so that $69 mag chuck would have been nice. I was going to toss the Roundtower mill on there too since they are all from the same place. One trip, three machines. It would a little crowded on a 16' trailer, but I think I could have squeezed them all on there. I'm sure I can pick up the lathe and surface grinder in one trip. But these will probably be gone too before my truck recovers from slippery clutch syndrome.
That's alright. These prices are typical I'm sure. In fact, they have some other choices similarly priced.
In fact, they also currently have this Sebastian lathe for $999
I'm torn between it and the SouthBend.
Because things move so fast I plan on calling in my purchase and then driving out to pick the stuff up. That way it won't be sold while I'm driving over to pick it up. So I thought I'd buy the SouthBend lathe officially, and then when I get there take a look at the Sebastian and compare it with the SouthBend. Maybe then I could get them to cancel the Southbend and grab the Sebastian instead.
Disclaimer: I'm dreaming out loud. It may not be until mid summer before I'm actually ready to pick anything up. So those who don't enjoy reading about a hobbyist's dreams are better off ignoring my posts.
That RoundTower mill was from this same place. But they just now got in a Bridgeport, but they want $1200 for the Bridgeport. I like the $895 for the Roundtower much better.
I'll keep dreaming whilst I replace the slippery clutch on my truck. Who knows what they'll get in next? They had a really nice Atlas lathe that went for $399. But it was gone the day it came in. It was a pretty large Atlas and had some extra tooling too. So you never know what to expect.
This place is about 200 miles from me and I don't like to drive far. So I'd like to jump when I can get a nice lathe, vertical mill, and surface grinder all on one fell swoop. All at prices I'm willing to spend. I'm looking for an "Instant Shop" for about $2500 all toll. I don't mind machines that need to be rebuilt. I'm a hobbyist remember. I'm not starting up a business.
