I have a 10" rotary table and a 6" indexing dividing head for my mill that are both in excess of 75 pounds - more than I want to lift and carry around. I have fabricated a light weight monorail out of Unistrut above the mill that will, with a rope/pulley system, allow me to lift them from the floor to the mill table. My plan is to build a wooden box on casters to hold them so I can easily store them under a work bench then roll them out when I want to lift them onto the mill. My question is, what would you recommend to put on the floor of the box to protect the bottom surfaces of the rotary table and dividing head? I don't want anything that would trap moisture against the ground surfaces. I have considered heavy felt which could be sprayed with a light oil, but am interested in other suggestions.
Thanks!
Mark
Thanks!
Mark
