- Jul 9, 2019
- 70
The only range close to me is an indoor range (50 yards) and that's the only place I can use my new 40mm launcher (unless I find a friend that lives on a farm out of town). They for sure don't allow explosive or incendiary ammo and don't allow use of projectiles that bounce off the backstop. I tried some real commercial police rubber rounds (called strikers iirc) but they bounced off the backstop all the way back to our feet so those aren't allowed. I would like to test a solid Delrin round and see how much it bounces back. These rounds will be just for range use.This looks pretty cool. Can you tell me more about the projectiles and intended use? Do you recover the blue projectile? Why round instead of stock? Do you launch other objects in front of it? What other kinds of load does this use. (aside from grenades!)
Robert
All of my home made rounds I used with my 37mm launcher (which you can launch "anywhere") were using Goex Fg black powder which has way too much smoke and fire to use indoors, so I was going to try Triple Seven or smokeless Trail Boss for the indoor rounds with Delrin projectiles.
At the end of the day when they sweep out the range they put all my projectiles in my locker for me so I can reuse them.
I wanted to try round so it looked more like commercially available rounds, and that it'd probably slide into the launcher slightly easier and possibly have better aerodynamics.
In Canada, having your firearm license allows you to manufacture some explosives (binary like Tannerite), and you can also get your pyrotechnics license and display fireworks class 2 license if you want to cook up even more special rounds. When I asked the local authorities if I could launch such items out of my launcher they said "don't do it" but couldn't give any reasons or laws against it. I looked through all the regulations and the only thing I can see is that the round can't detonate on impact, but time delay (fuse) is fine. I'm sure it'd be super unwise to launch a Tannerite round out of your launcher (even if it didn't blow up in the chamber it'd probably blow up on impact if it hit something before the fuse lit it off, which would make it illegal, even if unintentional). Flash powder would be way more stable and wouldn't detonate on impact, but if it ever lit off in the barrel you could kiss your launcher goodbye (at the minimum).
Other rounds you can shoot are smoke "grenades":
And there are chalk marker rounds, parachute flares (you shoot them straight up), some people shoot golf balls but the ones I tried were a VERY tight fit in the barrel (pretty much had to use a press to force it in), or D batteries
-Jamie M.
