Poor propellant bed ignition is the culprit behind the pressure spikes. It's not that the powder settling below the primer is getting "ignited all at once", it's that it isn't. It's a bit counter intuitive, but I've seen it first hand. If the ammunition isn't going to be handled much, you can load the propellant charge and then top it off with cream of wheat or corn meal (depending on which you like the smell of better, breakfast or popcorn). For ammunition that is handled enough that the propellant and filler might mix, you have to use something else. We even had some special cases that were partially filled with epoxy for a certain project in order to tailor the case volume to the load. And this was all with smokeless powder.
