- Jul 17, 2019
- 13
Quick PS: Obviously, you'll need to start somewhere. I can't visualize any way to mount an 8" piece of round stock on a 4" rotary table without first drilling a set of four holes that will line up with the t-slots. Maybe use a compass to lay out a circle (at 3" according to your original post?); then mill those holes first so you can at least mount it to the RT. Then proceed according to whatever pattern suits your objective.
I would suspect your FIRST measurement with a compass should be at @8" to make sure you're at or near centered. Then you're more likely to be where you want to be on the 3" circle.
Regards,
Terry
Thanks, I was already thinking that I would mount the plate to the table and then use it to drill the holes. My thought was to find the center of the plate set the dro to 0,0. Then drill and countersink the mounting holes for the rotary table 1.5" in the X Y directions. I have a plan in my head. I just need to work out the fine details before I drill the first hole.
