A relief on each flute? Can you describe or post a photo?I also grind a relief. (middle of second paragraph in my previous post)
I first grind the end of the tap flat to the first full thread, then I grind the end of each flute to provide clearance. similar to what would be done on an end mill. It would be the 1st peripheral relief angle in the drawing below.A relief on each flute? Can you describe or post a photo?
So, I have never done this when creating a bottoming tap from another tap. Wouldn't the relief already be in the existing tap already???I first grind the end of the tap flat to the first full thread, then I grind the end of each flute to provide clearance. similar to what would be done on an end mill. It would be the 1st peripheral relief angle in the drawing below.
I had a situation where I was making 10-32 threaded ports which had to hydraulically seal with fittings which had a full thread, hence the necessity to thread to the bottom of the hole
Grinding the initial flat will remove any relief from the tooth. Maybe not necessary if grinding with a precision setup but I just grind by hand so there is a distinct possibility that one of the flutes has negative relief.The secondary grinding ensures that it again has relief.So, I have never done this when creating a bottoming tap from another tap. Wouldn't the relief already be in the existing tap already???
I am only looking to cut the bottom of the hole, and I have not had a problem with my ground taps. I learned this from a machinist who gave me his box of tools. He had done this to many taps. I have continued to do the same.
well, again, I have been using my hand ground just pull the point off and remove leaving as many threads, and they have been working fine. Maybe not perfect, in a machinists eye, but they are doing what I need, which is to put threads to the bottom of the hole.Grinding the initial flat will remove any relief from the tooth. Maybe not necessary if grinding with a precision setup but I just grind by hand so there is a distinct possibility that one of the flutes has negative relief.The secondary grinding ensures that it again has relief.
I have just ground the point off as well which will generate some extra depth. That still leaves unfinished threads though. In the case I quoted above, I need to have a plastic fitting positively seat on the bottom of the hole which necessitated a fully cut thread close to the very bottom. There was a thin gasket so probably one thread away from the bottom. Ideally, these would have been done with a thread mill but I didn't have that capability at the time.well, again, I have been using my hand ground just pull the point off and remove leaving as many threads, and they have been working fine. Maybe not perfect, in a machinists eye, but they are doing what I need, which is to put threads to the bottom of the hole.
I wonder how much different having the relief vs not would show up in the thread. Maybe it's time to do a test and cut one open for each.
