I wouldn't want to do a lot of them, or really big ones, but, yeah, what @woodchucker said. Field expedient... Need a bottoming tap and don't have one, grind off the tip. Done.
Yes, thank you.I wouldn't want to do a lot of them, or really big ones, but, yeah, what @woodchucker said. Field expedient... Need a bottoming tap and don't have one, grind off the tip. Done.
I found just grinding the taper tap flat to the 1st good thread results in a hard to turn "bottom" tap. The relief grind makes it easier to turnA taper tap has between 5 and 7 partially formed threads, as opposed to 1 to 3 for a bottoming tap. You can cheat a little and grind the tip of a taper tap but you won't achieve the same result. You will have better chance with a plug tap which has 3-5 partially formed threads.
I have ground down taps to get closer to the bottom of a hole but usually stop at the point where the threads start cutting. I have cut a short chamfer on broken taps to finish a threaded hole after threading with a good tap. I grind the ends of a tap flat to the first full thread and grind relief as I would on an end mill. I drilled a 1/2" deep hole in aluminum and threaded with a 1/4-taper tap. A bolt would seat to a depth of .3". Switching to a bottoming tap, I could seat to just over .4". Then I used my modified tap and could seat to a full .5".
I have also ground a cutting edge and relief into a bolt to extend the thread to the bottom of a threaded hole but that was in plastic.
