Just chiming in a little late from some posts above. The 4-way is very rigid and I'm guessing yours has a detent ball so you can index to different positions and return to the original? Very handy when doing production jobs when you are using your cross feed/compound micrometer dials. Rotate your QCTP and your micrometer dials are off, have to align again.
Bruce
My Dad bought a surplus Le Blond 18" swing production lathe from A.O. Smith (Milwaukee, WI) in the mid '50's. It had a turret that had detents for angular settings. When we used an angular position other than the detent options the tool height was higher. (A-pain). Interestingly enough, the lathe was probably a dedicated custom build since it had no compound or threading provisions. She could really HOG steel though. Bottom line, SHIMS !
