- May 3, 2020
- 143
Some of you may have seen my unicorn milling machine floating around the site. Herter branded knee mill, made in Japan. Previously owned by an unknown individual who will be named "Blockhead" in all future references due to some repairs and maintenance choices I've found on this machine.
In a fit of boredom tonight I decided to remove the spindle and inspect it due to the general filth level of the machine when I got it, suspecting that it would be similar. The spindle has run quietly, and I put an indicator on it once but I couldn't tell you what the runout was, which must mean it wasn't enough for me to worry about it. Either way, I'm going to replace the bearings just for peace of mind.
The spindle/quill is dead easy to remove on this machine. After you remove the pointer for the quill depth scale and unbolt the quill lever assembly from the side of the head, the whole thing drops out as a unit.
Anyway, I found the spindle bearings to be packed full of old grease. It was still providing lubrication but struck me as odd, since I know spindle bearings usually run in oil.
So here's the question, grease or oil? I have no way of getting a service manual for this machine or know if anyone has been in here before me. Although I do suspect it based on some tool marks etc I noticed while taking it apart.
The only oiling hole on the head is this one on the side, located above the quill lever and mechanism:
Here is a view of it from the inside of the head with the quill/spindle removed:
With the quill installed, the side of it actually covers this oil port, and the quill has no oil passages itself. This leads me to think that this oil passages is just for lubricating the sliding of the quill against the bore. I don't see any way to get oil into the spindle bearings reliably.
Also, the bearings are completely open with no felt etc to trap oil. Any oil that gets to them would simply run out through the bottom of the spindle onto the work since there are no sealing measures.
With all that in mind, I'm inclined to say that grease is actually the best choice for these bearings, as strange as that seems. Although I am interested to hear what others think that have seen the inside of other machines, this is the only mill I've ever taken apart. And what grease to use for that matter if it is the best choice?
I am also wondering what I should be looking for in replacement bearings. The bearings are 7307B and 7208B angular contact bearings, as well as a 6208 ball bearing in the middle of the quill, seemingly just for extra spindle support. NSK brand. I don't see any additional markings on them denoting precision etc.
