- Jul 2, 2014
- 7,594
First rule about dealing with broken drills (and taps): Be really careful not to break them in the first place. It often a long fight trying to get them out, and work is damaged or ruined, with much time lost. A lot less time is required to carefully study the best way to drill or tap the hole you have in front of you, to really understand how to make a good hole or thread in the material you are working with, than to try to fix the much bigger problem after the tool is broken off in the work. The hurrieder you go, the behinder you get -- in my experience...
