- Dec 3, 2014
- 778
I use shim stock to level my BP clone. Toe jack comes in real handy, if you don't have one they are pretty easy to build, videos on youtube.
Very good information Mr. Projectnut. Thank you sir. I could have gone down the wrong road. I wonder if Randy ever drilled/tapped his BP?
I think I will just shim with an adequate material after I accomplish how to level it.
Why yes I did. Please see post 20 in the link in post 2 of this thread.
By the way I didn't have to drill the holes, just tap them. This is so much easier than trying to shim.
Hey Randy, is your casting down by the 4 holes solid or hollow? I wouldn't want to cause a fracture. pretty cool you didn't have to drill. As I recall they were 3/4 holes?
Thanks Tony, I hear your concerns. I have the machine tore down right now and thought now would be a good time to do it. And really the way the base is cast I only have to tap about 1-1/2 inches in the top part of the base. The rest is relieved. Thanks for the heads up. Oh, I was thinking the base casting should be of some quality as the knee ways are machined into it.
Well Guys, I did it. I tapped the base with 3/4-10, installed threaded rod. I topped it off with an polished stainless steel acorn nut. And roll pinned it together. I used a jam nut to lock them all in place. I may add a foof at the bottom later. Don't mind the picture, it is not as crooked as it looks.
