- Sep 22, 2010
- 7,226
From another forum:
"I was using Rustlick Synkool mixed with water as a cooant in my milling machine and all was going well,
-- Tools lasted longer,
-- parts and tools stayed cool,
-- splatter was controllable
-- clean up was easier
-- nothing rusted
-- no stinky coolant
-- Set up tools (clamps, bolts, parallels etc.) cleaned off easily
There were a couple of annomalies:
-- surfaces seemed to have a slight waxy feeling to them
-- sliding surfaces, even oiled ones like the ways, had a "break away" resistance the first time they were moved the next day.
AND THEN, when I least expected it. It turned on me !
-- A couple of weeks ago I noticed a bunch of speckles on a ground surface on the top of my vise. I scratched at them and they appeared to be black waxy lumps but they cam off easily enough
-- The next time I encountered the black waxy lumps they appeared on the far end of the table and on the ground surface of the rotary table. When i went to clean these off there was surface discoloration under the lumps, No pitting, more like a faint grey stain.
-- Then I found lumps under the vise base and under the rotary table base where they sit on the milling table and these looked more like rust but cleaned off fairly easily but did leave more discoloring.
-- I found lumps were appearing more and faster and even found some on a chuck I had not had on the mill for several weeks and was clean when I took it off.
-- Now the lumps clearly appeared to be rust and leaving marks on the surface but no pitting and the lumps would appear overnight
-- I also started to find some (not much) of the same on my parallels
I decided to clean up the machine thoroughly and in the process found that the dove tail on the ram between the turret and the milling head was orange! During the clean up, I found that apparantly water was evaporating from the sump, rising through the column and condensing on the bottom ofthe ram and causing rust. There were lumps of orange rust on the bottom of the dovetail (fortunately that is not a bearing surface. and what was on the bearing surface came off easily before I generously greased the whole thing. While cleaning up and inspecting the mill, I emptied, cleaned, flushed and dried out the sump and flood coolant system.
I also use a separate batch of the same cooant at a different concentration on my tool grinder as it prevents rust on the tool rest tables at both ends. I now was finding a milder case of the same phenomenon there.
Earlier in my experience I would have said the this syncool was the best thing since sliced bread, as I used it successfully for several months, but something has now gone wrong.
Contact with the manufacturer suggested several possible sources of the problem
A. The hard water I was using may be the #1 culprit (our water is very hard)
B. An accumulation of iron particulates in the coolant might be forming rust on top of the machine parts and then eating into the parts.
C. We have experienced rising relative humidity in the weather recently and now very high humidity
I should mention that:
-- I had to add water from time to time because the water would evaporate out of the coolant, but a salesman handling the Rustlick product said that this was normal.
-- I had to keep the concentration within bounds and do not have a refractometer to measure concentration but the range was quite wide, (i.e. as strong as 1 to 10 or as dilute as 1 to 25)
-- I was controlling tramp oil by intermittent skimming but never had complete oil cover in the sump.
I do not want to give up on flood coolant because there was so much it did for me in solving problems. So what I would like to hear about from the more experienced heads here is.
-- Are there causes besides A,B, & C that I should be looking at ???
-- Has anyone seen this sort of thing coming from hard water from a chlorinated fluoridated municipal supply
-- are accumulations of particulates in the coolant a problem that could cause this and if so how would one deal with this?
-- Is there some other water based coolant I should use that
------- also has very good resistance to stinking up the shop (in the house)
------- would give me better resistance to rusting problems
------- not break the bank to obtain. (i.e. not too expensive per gallon, and availalble in smaller quantities such as 5 gallons at the very most)
-- Is there a non water based coolant I could use that would serve better considering my situation?
And of course anything else beneficial you can offer me to solve the problem. That includes anything that you have seen in the way of similar problems and problems I have not encountered yet.
If I should be so lucky, that the problem is only the hard water, my solution would be to use a plastic external sump and demineralized water That would solve the problem of rusting on the bottom of the ram. I will probably have to do this for any water based coolant unless there is one that suppresses evaporation from the sump. Blocking the top of the interior of the column just does not appear to be practical by any means. I am surprised the sump was set up this way."
What is everyone's experience with these water-based coolants for home shops?
Thanks,
Nelson
-- nothing rusted
Thanks,
Nelson
