- Dec 24, 2020
- 1,278
Also don’t lay the pieces inline with the wheel. Thin materials should be at an angle. Light cuts.
Most of the wear in the ways will be in the center portion of the travel. Try to set up on the ends of the chuck and if you can move the chuck over to one side as much as possible. Indicator will show nothing about the taper of the ways.
SG are sold off when they are worn out, and we buy them for our home shops due to their precision capabilities. Companies are not willing to scrap the ways so rebuild the machine, and the machines are written down on their books over the years of use.
Unfortunately or fortunately most of us don’t need the ultimate precision that a new SG can give but can tolerate a worn machine.
There's only so much angle you can get with a 12" piece on my chuck, but I tried both angled and nearly parallel with the chuck axis and got the same results.
This SG has ball ways with V on one side and flat on the other. The shop it came out of went out of business when the owner retired and they had an auction. They had really nice stuff that generally went pretty high, this SG was clean and I don't think they did a lot of grinding (it was set up for dry) and the only SG in the shop. The picture above is how it looked when I unloaded it....it wasn't dirty and all beat up so I doubt it saw much use. I did replace the balls with new precision balls and the ways looked really good when I pulled the table. That's not definitive, but I don't think it was being used all day every day like many of the SGs you see at auction.
