• Welcome back Guest! Did you know you can mentor other members here at H-M? If not, please check out our Relaunch of Hobby Machinist Mentoring Program!
  • In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Winner Homemade Lathe Build Log
  • Thread starter Thread starter Andre
  • Start date Start date
Status
Not open for further replies.
I don't work in the shop on Fridays usually so any work done on Friday is a bonus.
Made a mock spindle and bored it then made a test collet. Worked perfectly, and it fits so well I have to hit the spindle for it to fall out.
Also locktited the bushing to the aluminum back. Hopefully it will hold.
No real need to show this, but I have a picture of it so why not.
locktiting the bushing in place worked well so I am locktiting the back curve of the slide in place.
Now drilling the spindle to .150"
Hole thankfully is straight as an arrow (not in flight!)
Now I tilted the head to 15* and bored the spindle to get the taper to close the collet. the major diameter of the collet is .250".
Here you can see it's bored out.
Now making some collet blanks.
Still have to machine them down some more.
Before I tilt the head back and tram it, I need to create a master taper so I can set the head back and make more collets or tooling (feels weird saying that for a lathe this small) for it.
Getting tired of turning on the lathe so I wanted to see some chips fly. Started work on the tailstock.
Thanks for looking.
photo 1 (7).JPG photo 2 (6).JPG photo 3 (6).JPG photo 4 (3).JPG photo 5 (3).JPG photo 1 (8).JPG photo 2 (7).JPG photo 3 (7).JPG photo 4 (4).JPG photo 5 (4).JPG
Now that's thinking ahead......A very essential part of machining.. Good idea....!:))
The little lathe is coming along, and looking good..!:))
Turned the collet blanks down to their shaft diameter.
Who needs pictures when you can have 30 per second? :))
[video=youtube;bKLk09MkGhY]https://www.youtube.com/watch?v=bKLk09MkGhY[/video]
Since there is a bit where the toolbit didn't reach on the last pass I clean them up a bit.
[video=youtube;6LzA0gGf_5k]https://www.youtube.com/watch?v=6LzA0gGf_5k[/video]
Used by height gauge again today, I love using it. Such a timesaver.
Awesome. Looked like the whole column was moving with the cam on the table
I was moving the knee up and down, and the camera (Ipod, can't you tell from the horrible pics in this thread:))) was sitting in a T slot.
Worked nicely.
Since I need to drill and tap into the backs of the collets for the 4-40 drawbar, I center drilled the backs of the stubs there still on.
Also did a lot on the tailstock today.
Drilled for the 5/16" tailstock ram, worked on the lock to hold the tailstock in place, and started work on the tailstock ram.
Made a little plug to become a lock. These plugs with the notch take awhile to machine. Easy, but they take awhile.
Some very careful eyeballing a center over a scribe line can get you extremely close. This is a 5/16" shaft on the dot with a 5/16" reamed hole in the tailstock. The spindle slips into the tailstock ram hole perfectly. That means the tailstock is aligned to the spindle probably within a thou or two. Not bad for eyeballing! Okay....I used a 7x Coddington magnifier. But still.
Next I shortened the tailstock because it's too tall. I would've loved to see this turn into chips flying all over but I like to save every bit of metal I can. Comes in handy later.
While knocking the corners off with a countersink I had a little crash. The countersink sucked the tailstock out of the vise and chowderd it up. So I had to cut a little off the side to get rid of the little mistake. Thankfully it happened while I had a good bit left to cut, so there was not much to clean up.
I flycut the sides of the tailstock and it looks really nice.
I don't plan to turn between centers so I don't need to put a lock on the tailstock ram. But I may in case the need comes up or it's future owner wants too.
Have left to do:
1. Finish tailstock
2. Make stand
3. Make box/motor mount
4. Finish cross slide
5. Toolpost for cross slide
6. Make flatbelt pulleys and some flat belts (flat belts transfer more torque than a V or round belt with less friction)
7. Cut keyway in round bed for tailstock alignment.
photo 1 (9).JPG photo 2 (8).JPG photo 3 (8).JPG photo 4 (5).JPG photo (43).JPG
Status
