Okay, not as much done today as I hoped. But I did make some progress.
Here is a mock-up of how the cross slide will sit on the lathe.
If I was planning ahead when I cut the top pieces of the female slide, I would've made it longer towards the back and bent it down to act as a bracket for the leadscrew to push against. But when I cut it out I procrastinated to figure it out later:angry:
So now I'm making that curved piece. It will be attached by a woodworking style lap joint.
Here is the piece ready to be bent in the vise "brake"
Now that it's bent I'm milling the ends at a 45* angle just for looks. A sketchy setup but it worked.
This is how it will sit on the back.
And this is after the lap joint is cut. I'm thinking of using red locktite to glue this in place, but opinions are very welcome on this!
So now I need a hole in that bracket for the leadscrew. And dummy me I drilled a clearance hole for a 1/4-20 screw not 10-24! I have done that twice today....did it before on the L bracket I made earlier. Good thing that one was a test. So I turned a bushing on my milling machine and I think this will work better than the bare aluminum. A mistake with a bonus.
And here is how the lower slide will look like. Still need to attach the back curve and drill the bushing through.
Thanks for looking!
