In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Nice job! For a note to ponder. The Levin manufacturing company (for example) has found that a 53° included angle works best for round belt drives. Apparently this angle has been found to have the best grip.
First run up was a complete success. Ran it for 15 minutes. Tomorrow I will reset the preload on the bearings or at least check it. Pictures to follow. I am extremely happy with this project.
Well Bill I am sure I speak for many of us that have followed this thread, when I say I have been very happy following this, and when it is all done will have withdrawal symptoms for sure.
The catch basin was first. Parts were purchased for this. I stumbled onto the SS part at Walmart. The assemble Pic #2. The drain pipe had to be modified to accept the strainer. The bore was opened up .060, 1" deep. The flange was made smaller and the inside radius made smaller to accept the rim of the strainer.
With a good belt and the bearings preloaded again, I ran it for 20 minutes and checked the run out at the nose. It is less than .0001. I used a .0001 gage. It is good to go. This may or may not hold, it depends on bearing wear. Only time will tell.
