In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Everything centers on the Base rail and micrometer adjuster. That's is all I got installed today. It's perfect. Tomorrow starting with the wheel head assembly we will up the pace a little (MAYBE). :rofl:
Moving toward the finish line. Spindle Base is bolted and squared to the rail. Nice welding Marcel. I didn't have to remove any of it. Thank you again.
No mist here Marcel, full flow adj. at the nozzle. The last of the sub-assemblies are mounted. The one with the wood ring is for location only. That is where the Tooth Rest will go.
The wood ring and short post have been replaced. Now the clamp and then the "Stylus". I will post a short account of what this part is for when I finish it.
