Inferno,
I have the Midas 1220 Ltd. It fits my shop and the range of machining I intend doing. Interestingly, the headstock/ chuck indicates
Which machine so you have and changes made?
Sent from my SM-P550 using Tapatalk
I also have the Midas 1220 LTD
The very first thing I did was change the toolpost holder out for a quick change. I bought a cheap aluminum one and had to make a few modifications (and I screwed up a little) to get the toolpost to fit but I won't go back to the original one. Someday I might get a better quick change but this one works.
I also added the YURI DRO on all three axis. I added a tach on the lathe head as well.
I'm in the middle of adding a drill stop on the mill head. I had a DRO on it but never secured the wire going to my bluetooth board and I had a bird nest grab the wire and, well, I'm going to fix it some day.
I removed the front/back slide and, for the life of me I can't remember how, modified it slightly to take up some of the slop. Whatever I did, I need to do better because it's gotten sloppy again.
An unintentional modification came from a crash I had with the horizontal axis, in power feed, crashed into the frame and broke some stuff. I replaced the gear hub that broke (and bought a spare) but haven't fixed the housing that broke.
And I added a softer pin to the horizontal screw so it will, hopefully, fail if I ever crash it again.
I know I did a couple other things but don't remember off the top of my head.
I really like the machine. I get within .001" any time I want with the DRO.
