Inferno, thank you for your kind words. What sort of board/scales did you end up using? I'd be curious to see your setup.
Off-topic: assuming your profile is correct, we are pretty much neighbors. I don't know how many hobby machinists are there in PDX metro area, but once the bubonic plague the pandemic is over, it would be nice to get a few of us together with a few beers and BS about this.
Regards
Yuriy
Well, I got the board from you, I'm pretty sure. I modified things a tiny bit, as I recall. I had a small issue about 4 months after I got it and my memories of that time are a tiny bit fuzzy.
The scale I used was, basically, this
I don't know if it had a name brand or not. I bought three scales. I ended up breaking the shorter one. It was an easy repair but that's when my "event" happened and the parts got separated so I have to locate it again. It's the scale for the vertical on the mill part.
Kind of went off the rails there.
I can't access the emails from back then, right now, though I know they exist. If I could then I could tell you exactly what I bought from you and what the rails were. Suffice to say, the image above is a great representation.
The other two axis have performed flawlessly except, as I said, the power on hiccup.
I wasn't aware you were local. I don't drink but I'd sit with you while drinking a Pepsi. LOL
You can have beer!
