Steve,
Marketing plays games with HP ratings. My air compressor also claims to be 5HP. -No way. It pulls 18 amps steady-state which is about 3HP so, I'm guessing the initial current draw (which is probably 2-3 times steady state) mathematically puts it in the 5 HP range -for about 3 seconds.
No matter how you slice it, efficiency is rated as output / input. If a motor is mechanically putting out 1 HP it must be supplied at least 1 hp + power to overcome inefficiency (friction and heat losses etc). If a 1 HP motor needs 16A, it's very inefficient -but possibly that inefficiency helps it obtain a higher service rating (i.e. it has a massive rotor with a lot of inertia). -Don't know, it's been 30 years since I studied that stuff and much of it was electromagnetism and the math behind it.
220 motors of the same HP pull the same amps but, the current is spread across another wire (they have 2 circuits of 110). Each circuit carries half the load so, the breaker on each circuit is less likely to trip.
When you run extension cords, there are electrical (resistance) losses in the long wire which consume power along with the motor at the end of the wire. The circuit breaker doesn't care, it just knows too much current is being pulled so it trips. Sometimes it doesn't trip right away because it takes a while for the extension cord to heat up. Generally speaking, resistance increases as temps get higher.
And finally, yes, motors are inductive loads causing the current and voltage to be out of synch. This is why some motors have a Run Capacitor. Capacitors are opposite of inductors so, adding a capacitor normalizes the power factor. When the power factor in a line gets too high, it causes problems with the electrical meter and can cause problems with other appliances. And finally, there are start capacitors... When a motor has a start cap, it has two sets of windings and the cap is only connected to one of the windings (the start windings). The cap causes one of the windings to oppose the field in the other winding because, some designs of motors need an initial counter-torque to get them spinning. There is also a centrifugal switch so once the motor gets up to speed, the start winding and cap are switched out.
There..... Motors 101. At one time in my life, I probably knew the details of about 5-6 types of motors but, now, I just care how much they weigh, how often I have to move them -and if they work good or not.
EDIT: When a 220 line is wired, one circuit must come from one tap off the breaker panel and the the other circuit comes off the other tap. The taps are 180 degrees out of phase (i.e. as one is high, the other is low). You cannot take two 110 lines from the same tap to power a 220 motor.
Typical FLA (full load amps at rated shaft power) for a 1 HP motor is around 16 amps.
6.4 FLA amps on the Harbor Ft motor gets you between 1/4 and 1/3 HP on the shaft (and a little less than that after you go through the gear box).
Terry S
if 1hp at 110v needs 16 amps how does my old craftsman 110v air compressor with a 5hp motor run on my 20 amp breaker? would that not need 80 amps with this math
i'm not trying to be a smart a.. i'm curious
steve[/QUOTE]
