- Nov 16, 2012
- 5,596
Volts x Amps = Watts
Assume your line voltage is 120 (it's usually betwee 115 and 123 in the US).
120 x 6.4 = 768. There are 745.6 Watts per horsepower so, you're motor is just a tad bit more than 1HP.
I beefed-up the base on mine a little and raised the height so I don't have to work like a cave man. Pic isnt too great but it's just some angle iron bolted to the corners following the angle of the existing base. Eliminates the tip-over problem...
I just bought a new one from HF a couple of months ago.
Now the color is a maroon-red.
The motor is TEFC cap-start, 4 pole rated at 1725 rpm.
The nameplate says 1 HP, but the FLA is 6.4 amps. So, it's really about 1/2 HP.
Not sure how the Chinese come up with 1 HP.
Once you get the belt guard properly fitted so it doesn't rattle, the saw is fairly quiet.
It still amazes me though, how the Chinese get their motors to hum as much as they do.
I was a little surprised to find the gearbox free of chips and filled with clean gear lube.
I left off the wheels so that I am not temped to move it that way.
Once leveled and in place, I feel the sheet metal stand is OK.
I went through the usual tear-down, cleaning, and alignment before use.
I have already cut a fair amount of steel with it. It actually cuts pretty square.
Buy a couple of good quality blades - the one that comes with it is pretty weak.
Oh - be sure to install the safety pin on the back every time you leave the saw not running.
If the pin is not installed, it is easy for someone to lift the saw, have it go over-center and tip over on the floor.
Hasn't happened to me yet, but I can see why many people warn about this feature.
Terry S.
