I see missing info and dumb dimensions. Examples (referring to the top piece):
1. There's a 2-9/16" dimension between the rightmost hole and an unspecified (and unmeasurable) location on the 3/4"R hole.
2. I see nothing to give an overall height from top flat to bottom flat.
3. And of course one portion of that bottom flat that isn't specified is the X axis of the 3/8" radius in the corner.
4. What's the Y axis value for the 1-1/2" radius?
I can understand how some of those dimensions may not be critical, but #4 certainly is. A good drawing would provide reference dimensions (so labeled) in any case.
That's without really digging. If they're that bad on the surface, things probably don't improve as you go deeper.
GsT
