It is an Atlas 10F Series lathe. The numbers cast into the two covers are both the casting numbers and the part numbers. You will find similar numbers cast into most of the cast iron parts, and most of the change gears.
The nameplate, with Model Number and Serial Number, was apparently originally on the right end of the bed. The photo of the right end shows one rivet hole and the other rivet with head broken off and painted over. So it has been repainted. You can look on the top of the right end of the front way for some letters and numbers stamped there but the practice of stamping the serial numbers there ceased with little if any overlap when the nameplate was moved from the rear of the bed to the right end. So there is probably nothing stamped into the front way. That would date it to 1942 or later. Scaling the swing from one of the photos gives a bed length of 48". So the size is 10" x 30". The 48" and 36" beds went out of production around late 1946 or early 1947, shortly before the first QCGB appeared. So the original model number was TH48 as there were no QC48's made. Since there were no QC48's made, the QCGB was added between 1948 and 1951, when the second version of 10" QCGB came out. The headstock is the later one with the rectangular opening for the motor switch. That change also came out circa 1942.
To summarize, it was probably made between 1942 and 1947. It started life as a TH48. And it was later upgraded to QC48. The possible serial number range is about 030000 to 080000. Which unfortunately accounts for over half of all 10" made.
Should you ever have reason to pull the spindle, you will find hand engraved into the cup and cone of both bearings the inspection date or dates. Please report those in the thread at the top of the Sticky area.
