- Dec 10, 2023
- 85
Hello, i have not done any lathe work. So bear that in mind.
I am designing my own 4th axis for my Tormach 770.
I have lots of experience with Stepper motors and harmonic gears that i will be using to make the 4th axis as i build astronomy mounts that use them.
My questions revolve around putting a Lathe Chuck and Collet chuck on the end of the harmonic gear box.
I do not know anything about spindle noses that 3/4/6 jaw chucks and collet chucks attach too.
I attached the bolt pattern that is on the harmonic gear box to this post. You can see the bolt pattern has a diameter of 54mm or 2.126 inches.
I would be using a 4 inch chuck most likely.
If anyone has suggestions on the best nose to buy/make/use for this application please let me know.
Thanks!
Chad
Thanks!
Chad
