So I am new here and pretty new to machining in general (Ive used a friend's 3-phase lathe a few times and had a mini lathe for a while).
I recently got a new to me Enco 92030 from 1983 (Its a 12X36 I believe). A friend who knows a little bit more about lathes in general than I do bought this lathe for me and verified that it looked pretty good and worked. He's in Vegas and I live in Peoria, AZ. After he got the lathe I went up and retrieved it a few months ago. It has some tooling including a 3 jaw chuck, 4-jaw, quick change tool post, and more.
I found some thread here suggesting that the closest manual to what would be original to this lathe is the one available as a PDF for an Enco 110-2033 lathe. This manual seems to be mostly correct but also doesn't have much detail or specifics...especialy when it comes to the wiring and or switches. Just a fairly generic wiring diagram that seems to be mostly correct.
Anyways its been hot as hell here, as is usual, and I have slowly been working on tightening and fixing the heavy bench that the lathe came with ahead of cleaning it and learning to use it.
With the bench tightened and partially re-built I wired up a plug to match my 240v outlet (which is supposedly what the seller had it plugged into) and it does in fact turn (counter clockwise)...but regardless of what you do, the switches don't change that, and you have to unplug it to stop the machine. Luckily the first time I plugged it in I made sure that the auto feed stuff was disengaged and there was nothing in the way of the chuck!
It seems to have the forward/reverse shift lever on the right of the machine (like other lathes Ive used) which seems to be in the neutral, center position and I haven't messed with that lever while its plugged in.
It also has a large red kill switch that you have to turn and pull to activate I'm guessing?
There is also a green start button next to the kill switch.
It also has an electric switch for a fluid pump which seems to be missing from the lathe and the switch is just a hole filler in the switch pannel.
As for wiring its got a lot. It has what I assume is a breaker that says 15A, two magnetic contractors, and a machine tool transformer which I gather is what allows it to work on 110v, 220v and possibly three phase (Although I believe that would require a different motor?...the motor says single phase and has 4 wires coming from it).
My problem now is I am not sure where to start figuring out if its got a bad switch, faulty wiring, a stuck relay/contactor, or what. Hell I am not even sure I know how the switches on the lathe are supposed to work. All I know is if you plug it in the chuck turns counter clockwise with some authority.
The mechanical switches that control the screw feed seem pretty straightforward and I can see how they would change the direction of the screw feed parts and or disengage them, while playing with them with the machine unplugged.
Soon I can post some pictures (as a newbie) and maybe someone here can help me figure out what is wrong with this machine. I'm hesitant to start taking stuff apart or messing with the wiring until I at least have some basic idea of what parts do what.
Thanks in advance!
Thanks in advance!
