I id but not correctly. I am still working through it, But I did find out the switch is not the double L but a diffrent style when I did a continuity check to compare switches.
Ok, so I was looking at the different diagrams today and think I found a way that will work but I wanted more opinions before I hooked it up, and if I still think its the Thermal protection I will bypass it. I have also included the continuity diagram of my switch. Any input will be apricated. First pic is the continuity test of the switch it is not the double L and the second one is what I think will work.
