- Jan 16, 2020
- 0
Wow! Now, I am afraid to fire my new Remington 1858 pistol! Seriously, a good discussion, and I appreciate every word. Thanks to Hobby Machinist and to all. For the record, I purchased a bottle of Pyrodex P, ~FFFG Equivalent. I hope that is correct.
No need to be afraid, Jim. I've got an 1858 Remington New Army, and they are a blast to shoot. Pyrodex P or FFFg is just the right thing to use. Tip: 22 grains of powder, topped with 22 grains of farina or cream of wheat followed by the ball is perfect. Here is the deal with revolvers: They were originally designed to use 45 grains of 2F powder. Back in the Civil War, you didn't stock one powder for pistols, and another for rifles, you stocked just one powder. Keep in mind that quality control back then was not what it is today, either. With 45 grains in the chamber, you could press the ball down directly on top of the powder and life was good. Now, with 3F powder, you don't need near as much powder, so you pour in 22 grains but now you have an air space between the powder and the ball because the loading lever is not capable of pushing the ball all the way down to the reduced powder volume. As a result, you need a filler material such as farina or corn meal. Once you press the ball home, it should stop just below flush in the cylinder. If it sticks up it might jamb up as it comes in line with the barrel. Just make certain that you have no air gap between the powder and the ball. DO NOT be tempted to try 45 grains of 3F. The pressures are too great, resulting in cracks in the webs between chambers. Once they are cracked, you'll get chain fires and they are REALLY SCAREY, lead goes in every direction!
I guess I'm on hold and just doing a little more research for a few more days, Unable to bend fingers makes it hard to machine and type. Thank god for spell checker. So I have a partial test barrel on the lathe. waiting for me to get back to it. Now just to figure out the bore I want..177 or .22
Personally I would go with .22 as small calibers foul up very quickly. The larger the bore the better, but you will still need to run a cleaning patch after every shot.
