- Mar 5, 2024
- 14
(MX-S716G) Rewiring the electrical wiring is easy, the on/off switch (Start/Stop switch) must be connected directly from the spindle protection switch. The wire of the direction changer, which goes to the On/Off switch, must be thrown away. For me, this wire is red. After that, there is normal mode, you don't need to mess with the direction switch for proper operation. Switching sequence Green button, the display lights up or shows the revolution. Unfortunately, by default it rotates at 126 per minute, there are no 0 jobs. I installed a back-up switch that breaks or closes the reverse input wire (R - L switch). In this way, I exclude the immediate rotation of the spindle after switching on.
