- Feb 8, 2014
- 11,187
That was my thought. I tend to be a numbers guy, so I was curious how exactly to specify "just a bit loose".
I tend to work to exact measurements in my home shop and I'd like to make all the parts interchangeable if for no other reason than good practice.
That's kind of like ''normal tightness'' I honestly don't know what the numbers might be. In our case, we make a few hundred of the ''nuts'' first (all the same, done on a CNC mill) then test fit the threaded end of the tube on a few random parts. The tubes are also done on a CNC lathe, so once set, they are all the same. It basically should spin on easily with 2 fingers.
Assuming you can make one or the other part all the same, then interchangeability should not be a problem once you get the fit as you want it. If you are doing this on manual equipment, then make all of the rings first. Then you can use the rings to test fit the external threads. Once you find the tightest ring, then use that as your thread gauge. Go for a fit that easily spins onto the external thread, note the numbers on the dials, and make the rest of the parts exactly like the first.
