- Dec 2, 2012
- 1,788
Those double slides tend to bind when you get them too far apart. If you can back off the upper slide from its travel screw and remove it, it may make it easy to slide the lower one off. I would NOT remove the thumb screws, they have peened ends to prevent them from falling out in use.
My point being the bind is more likely mechanical, but what do I know. Someone could have put Krazy Glue on it before oiling and storing.
Is the peening of the screws a starrett thing? I've had other brands out to clean or sometimes fall out at inappropriate times when in use.
I have an old caliper they have put pins in the lock thumb wheel to stop it falling out, nice but I have no idea how you would disassemble it.
Stu
