- Jul 2, 2014
- 7,594
The height gage has been tested, and the scale is accurate to the distance under the standard height gage blade. It works fine as built, just does not measure below 1.040" using the standard blade. The only issue here is being able to measure shorter parts. Using a 1-2-3 block conveniently lets one measure down to .040" by simply subtracting 1.000" from the scale reading. 1.000" offset blades are also available to fit the height gage, still need to subtract 1.000" from the scale reading. The only issue here that we are fussing over is the .040" that the slide cannot reach because it hits the base first. Much ado about nothing, IMHO...Personally I would,
1. Accept it as is and simply deduct 1.040" from whatever it is you are measuring. or,
2. make a nice plate that is 1.040" thick and sit anything you want to measure on it. or,
3. Make an extra piece that adapts the scribing foot to the height gauge, and problem solved.
